Transmission will not shift
1989 DODGE RAMCHARGER
ZAREN
V8 four wheel drive automatic 130,000 miles.
Hey all,
Sat not being used for almost a year.
I bought it pretty cheap and do figure I will need to do some repairs.
It was bought from an estate sale and I was told it ran but shifted sloppy.
I started it up,ran great, no smoke, noises etc. Checked trans fluid. Was a bit low. Brought up to temperature,topped off and proceeded to drive home.
After a mile I see that it would not shift out of first gear by itself or moving the shift lever.
Transmission fluid was clean and did not smell burnt at all.
Called AAA to tow rather than risk burning up the trans.
While waiting for the tow I got underneath to inspect and saw no obvious signs of leakage.
However, I did see that the trans cooling lines were cut and diverted back to the transmission using rubber tubing! As well as the lines to the radiator were also looped backwards to the radiator...
My questions are,
1- Why would someone loop the lines as such?
2-What transmission do I have?
3- With a good working first gear(no slippage),why would the trans not up shift any further?
4-Are there any common problems with these transmissions I should be aware of?
5-Aside from repairing the cooling lines are there any obvious first run checks I should make?
Thanks in advance for your help!
Zaren
Jun 24, 2010 at 12:43 AM
CARADIODOC
  • 34,381 POSTS
Hi Zaren. Welcome to the forum. The transmission you have is either the 904 or 727. The pan on a 904 is basically a rectangle with one corner shaved off a little. The 727 is the same but has an extra 2" bump-out on the right front corner. It was a really tough unit until they hung an overdrive gear on the back of it . Both transmissions use the same valve body, mounts, and external linkages but the clutch packs and other rotating parts are larger in diameter than the 904's. Both are easy to rebuild. Unlike GM and Ford transmissions that require a box full of special cones and tools, the Chrysler transmissions require a three-dollar seal tool for the clutch packs. I had rotten luck with the front clutch piston seal on the 904. There are tricks to installing it without cutting it, but I wrecked that seal twice so I gave up and installed a 727 instead in my car.
I cannot say what the differences are related to hooking it to a transfer case, but up front there are three versions of each transmission. One case bolts to the slant six cylinder engines. Another one bolts to any small block engine, (273, 318, 340, and 360), and one case bolts to the big block engines, (361, 383, 400, 413, 426 wedge, 426 hemi, and 440). The 727 can be bolted to an engine in place of the 904 but the tail housing is 4" longer so a 4" shorter drive shaft is needed on cars. I think the tail housing is removed when it is bolted to a transfer case, but I cannot remember for sure.
The cooler lines may have been leaking or the cooler itself might have been rusted through inside the radiator. If you pull off the hose from cooler in the radiator and see green antifreeze come out, the cooler is leaking. Hose pressure from the transmission can reach 10 psi, but coolant pressure can reach 15 psi so coolant will be forced into the transmission when the engine is hot. Transmission fluid would be forced into the radiator when the engine is cold. The coolant will be dark brown and rubber hoses will be soft and mushy. Petroleum products such as transmission fluid rots rubber hoses from the inside. If the cooler is leaking internally, it would be less expensive to add an external transmission cooler in front of the radiator than to replace the radiator.
If you see red fluid or nothing at all from the cooler lines, chances are the steel lines were just leaking. The original lines had no rubber hoses anywhere in them. They were solid steel all the way from the transmission to the radiator. They were long enough to flex with engine vibration and movement.
As for not shifting, there's a good chance there is varnish buildup in the valve body. First look at the kick down linkage. If it still uses a series of metal rods from the engine to the lever on the driver's side of the transmission, it could be disconnected. If the lever is sitting in the position of wide-open-throttle, it will need a really high road speed to upshift. Newer versions use a cable that can get rusted tight and stick in the heavy acceleration mode. That lever should move freely by hand and spring back to the low throttle position easily when released.
If the linkage is working freely, suspect varnish buildup in the valve body. The shift points are set by two valves; the throttle valve which is connected to the lever you just checked, and the governor valve on the output shaft. The spring-loaded governor valve moves in its bore from centrifugal force due to drive shaft speed. When its pressure due to road speed overcomes the throttle valve's pressure due to gas pedal position, the shift valve moves to initiate the gear change. The most common symptom of a sticking governor valve is a failure to downshift to first gear when you slow down but it could also prevent an up shift. As I recall, the throttle valve is not spring-loaded. It has to move with the kick down linkage. A shift valve could also be sticking. Most of those valves do not use springs, just fluid pressure to set their positions.
Before you tear into the transmission, you might try an additive that is supposed to dissolve any varnish buildup. Some must be drained out after doing their job. They are not meant to be left in for a long period of time. Other additives are designed to remain in the transmission. These are commonly called "shift improvers".
caradiodoc
Jun 24, 2010 at 7:11 AM
ZAREN
Would you think any bands or clutches would be bad as I do have a good first gear and reverse?
I connected the transmission lines, no antifreeze just a little fluid and not burnt. Does not seem to leak at all.
Like I said, I do have a good first and reverse gear.
Zaren
Jun 24, 2010 at 7:23 AM
CARADIODOC
  • 34,381 POSTS
Worn clutches will make it slip in that gear. Your transmission has not even made it to a different gear yet for slippage to be evident. The only thing that a band will do is break on the end. You will not have reverse and it will not stay in manual low when you put it in "1". A broken band will let it shift to second gear instead of staying in first. A low/reverse band that is adjusted too tightly will cause overheating. If it is too loose, engine flare-up will occur during the up-shift from first to second gear under very light acceleration. There is no sign of it trying to go into any other gear besides first. That rules out clutches and bands and points to a valve or linkage problem.
caradiodoc
Jun 24, 2010 at 9:55 AM
ZAREN
CEL light was on and revealed a code 37. Can this have anything to do with it? Part throttle unlock circuit.
I saw the return spring was broke on the passing gear linkage and repaired to no avail.
Going to try the varnish cleaner next.
Do not want to replace this transmission if its still good.
Jun 24, 2010 at 10:04 AM
CARADIODOC
  • 34,381 POSTS
That code just refers to the lockup torque converter. That has nothing to do with the rest of the transmission. The lockup system is just for better fuel mileage. It eliminates the speed difference between the engine crankshaft speed and the transmission input shaft speed. That difference in speed is what allows it to be in gear but stopped without stalling the engine. Eliminating that little slippage slows the engine down a little at highway speeds. The clutch used to be controlled hydraulically in the valve body, but is now controlled electrically by the engine computer. The entire circuit can malfunction without having any affect on the rest of the transmission.
caradiodoc
Jun 24, 2010 at 10:40 AM
CHOCOCAT
Hey guys, thanks for this comprehensive write up. I too have a 904 in a 1990 Ram van. It was replaced about 10,000 miles ago, in 2003. I just got the van, and I am having a similar issue. I can get the transmission to shift in to second gear, but only at high rpm, and full throttle. I cannot get third, either it will not go or I will not take it there. Been to 50 mph and would not shift. I discovered a disconnected lockup sensor, I reconnected it but still have the same problem. I do not know much about these things, but
1. The downshift linkage was connected(although I have a question about that).
2. The downshift valve returns and moves freely.
I discovered the linkage would not let the downshift valve return to a fully closed position. Shooting in the dark I adjusted that linkage to start to engage after throttle is applied. Still no change. Varnish on the valve body seems to be a likely candidate. Is there a preferred brand or type of these shift helpers? Thank you
May 9, 2018 at 8:02 AM
