take the rotor off the truck, lay it on the ground with the lug nuts facing up, take a big hammer and knock the lugs out. mine seperated when i did this but if your hub is frozen to the rotor you might need to put it in a press. the lug nuts are holding the rotor on. you can install it the same way but i tried it with a punch and hammer and there was still slack inbetween the hub and rotor, had to use the press. good luck hope it works out for you.
Jan 27, 2009 at 2:46 PM
