1985 Dodge Ramcharger non working 4WD
1985 DODGE RAMCHARGER
132,000 MILES • V8 • 4WD • AUTOMATIC
GREGCCBERG
I'm looking at buying a 1985 W100/150, but the owner says the 4WD doesn't work. He said his friend told him it was front bearings/hubs/etc. and parts would cost about $350. I've worked on plenty of cars, but never a 4WD, and wanted to see if this sounds right, or if I should be thinking transfer case. What questions should I ask to try to narrow down the problem?
Jan 17, 2009 at 3:19 AM
  • 110,240 POSTS
Actually, check the vacuum lines from the engine to the transfercase and to the front axle. There is a vacuum pod in the front axle that may be rusted, not allowing the 4wd to acuate.
Let me know what you find.
Mar 12, 2009 at 10:51 AM
