1985 Dodge Ramcharger just changed water pump
1985 DODGE RAMCHARGER
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
GLEBLUE
just changed water pump now the truck is sluggish and smokes alot im concerned that water got in the engine when i looked at the oil it did look that light color what can i do to get it running strong again thanks
Feb 6, 2009 at 11:14 PM
  • 110,244 POSTS
Change the oil and make sure coolant isn't leaking into the engine via a bad head gasket. Also, recheck everything to make sure you didn't leave any vacuum lines off.
Mar 12, 2009 at 10:44 AM
