1984 Dodge Ramcharger LOSS OF POWER ONLY UPHILL - HELP
MACKATTACK
Engine Performance problem
1984 Dodge Ramcharger Two Wheel Drive Automatic
My 1984 ramcharger 360ci, losses power when going up a steep hill - does not die - like it run out of gas.
Idles and accelerates fine on flats. I am the orginal owner and know the vechicle well - billet mopar distrubrator, Jacobots ingition system, Holley carb, heat riser in exhaust manifold removed.
Sep 10, 2009 at 12:23 AM
  • 110,246 POSTS
Have you checked the fuel pump pressure?
Jan 25, 2010 at 12:26 PM
