WATER NOISE
RUECKER
I HAVE A 1997 DODGE RAM 1500 TRUCK
5.9 V8 MOTOR - AUTO TRANY - SHORT CAB & BOX
TWO WHEEL DRIVE
I HAVE A SLOSHING WATER SOUND COMING
FROM THE HEATER/AIR COND. BLOWER BOX AREA
WHERE IS THE DRAIN HOSE/HOLE
WHAT IS THE CORRECT WAY TO CLEAR IT
BLOW AIR- PUSH A WIRE- REMOVE AND CLEAN
ADDED NOTE:
THERE IS NO ANTIFREEZE SMELL COMMING FROM
THE VENTS AND I CHANGED THE RADIATOR
2 MONTHS AGO AND HAVE NOT USED ANY
ANTIFREEZE SINCE THE RADIATOR CHANGE
ALSO THERE IS NO WETNESS ON THE CARPET
THANK YOU RAY U.
Oct 18, 2007 at 3:57 AM
BLACKOP555
  • 10,386 POSTS
sounds like you have a bad heater core that has leaked and filled up its compartment. to get it out you have to remove the dash if the heater core is not located behind the glovebox.
Oct 19, 2007 at 3:41 AM
