Surging motor Dodge Ram 50 import 1992 FI
JIM COLLINS
This Mitsubishi motor runs fine for an indefinite period then begins surging to such an extent as to be undriveable. A Dodge mechanic analyzed it and assured me it was the Idle speed control (or Idle Air Control), which I replaced, and the problem remains the same. Someone else suggests the EMC or engine control module .
Feb 20, 2007 at 1:40 PM
2CARPRO JACK
  • 11,533 POSTS
If there are no vacuum leaks, and the minimum idle screw has never been touched then you should try cleaning out the throttle bore. Use a little carb spray and a rag to clean where the air intake hooks up to the engine, clean all around the throttle plate
Feb 21, 2007 at 12:11 AM
