Steering vibration
DODGE RAM
LYNN GUYER
I have a 96 Ram 2500 V10 Automatic Transmission. Recently when turning corners the steer wheel starts to bounce. When going straight it is fine and holds steady. It does this turning both right and left. Any ideas?
Sep 27, 2007 at 11:05 AM
MERLIN2021
  • 17,250 POSTS
Are you hearing and clanking, or clicking when you turn? If so you may need a u-joint or two! Check you front axle! That is if it's 4X4, could also be worn front end parts! Check ball joints...
Sep 27, 2007 at 11:08 AM
