1997 Dodge Ram Spark Plug Wire Order
NHFFEMT
1997 dodge ram 318 with a 5.2
aprox 170k miles
during tune up when replacing wires to the cap a few of them just simply fell of their ignition points
was wondering where i can find a diagram of the proper location as so the truck will fire in the right sequence
Sep 19, 2007 at 2:45 AM
SERVICE WRITER
  • 9,123 POSTS
if you are on the driver's side and looking at the motor, the front will be on your left.
The cylinders on the passenger side will be 2-4-6-8 going left to right.
The driver's side are 1-3-5-7, L to R.
The firing order goes 1-8-4-3-6-5-7-2.
Clockwise.
The number two cylinder is between both heads at the front of the distributer. The number one is next going clockwise and is probably the closest to the passenger head. The number 3 is at the firewall opposite the #2.
Sep 19, 2007 at 4:48 AM
Suggested Repair
Reinstall the spark plug wires using firing order 1-8-4-3-6-5-7-2, clockwise on the distributor. Viewed from the driver's side with the front of the engine on the left, passenger-side cylinders are 2-4-6-8 left to right and driver's-side cylinders are 1-3-5-7 left to right. Terminal 2 is at the front of the distributor between the heads, terminal 1 is next clockwise nearest the passenger head, and terminal 3 is at the firewall opposite terminal 2.
Conversation Summary
The owner of a 1997 Dodge Ram with a 5.2 (318) lost several spark plug wire positions while replacing wires during a tune-up and asked for the correct firing sequence. The expert gave the cylinder layout and clockwise firing order 1-8-4-3-6-5-7-2, including distributor terminal positions.
