aprox 170k miles
during tune up when replacing wires to the cap a few of them just simply fell of their ignition points
was wondering where i can find a diagram of the proper location as so the truck will fire in the right sequence
Reinstall the spark plug wires using firing order 1-8-4-3-6-5-7-2, clockwise on the distributor. Viewed from the driver's side with the front of the engine on the left, passenger-side cylinders are 2-4-6-8 left to right and driver's-side cylinders are 1-3-5-7 left to right. Terminal 2 is at the front of the distributor between the heads, terminal 1 is next clockwise nearest the passenger head, and terminal 3 is at the firewall opposite terminal 2.
The owner of a 1997 Dodge Ram with a 5.2 (318) lost several spark plug wire positions while replacing wires during a tune-up and asked for the correct firing sequence. The expert gave the cylinder layout and clockwise firing order 1-8-4-3-6-5-7-2, including distributor terminal positions.
