Running rough after plug change
MHALEY
I have a 2000 dodge ram 1500. I changed the plugs and the truck is running rough. As I changed the plugs I kept the wires in order by doing them one at a time. All the wire connections are good.
Any suggestions?
Thanks,
Mike
Jul 7, 2007 at 1:49 PM
SERVICE WRITER
  • 9,123 POSTS
As silly as it seems, recheck the wire routing anyways. Are plugs correct and is the gap correct? Check for anything you may have disconnected (connector,vacuum hose etc) to get to a plug weather intentional or not.
Jul 7, 2007 at 4:07 PM
