95 ram 1500 runnin hot. replaced water pump,thermastat,fan clutch ,and serpitine belt and still not fix
Jul 8, 2007 at 12:27 PM
TATTOOMAN
MEMBER
[quote:bc237bee0d="tattooman"]95 ram 1500 5.2 runnin hot. replaced water pump,thermastat,fan clutch ,and serpitine belt and still not fix[/quote:bc237bee0d]
Jul 9, 2007 at 2:24 PM
PREDOGGG
MEMBER
Have you had Radiator flushed cause your fluids could have become acid base if left in too long and cause corrosion in the radiator and therefore cause your truck to over heat
