Differential
HMAC300
  • 48,601 POSTS
No more than likely it will spit oil out the vent on top of axle. Just pull the fill plug until it quits draining on a level surface and will be filled okay.
Sunday, September 1st, 2019 AT 12:07 PM (Merged)
BIGDAD50
  • 2005 DODGE RAM
  • V8
  • 4WD
  • 36,000 MILES
How much to replace the front differential
  • 109,885 POSTS
I would estimate a used replacement with labor to be around 1200.00. Make sure the gear ratio is the same as the original one.
DICK61045
  • 2001 DODGE RAM
  • 6 CYL
  • 4WD
  • 51,000 MILES
This is a 2500 diesel that has differential gears (3?) That are not the best for towing my heavy 5th wheel trailer. Is it possible to install gears that will help improve towing performance? I think the gears I am referring to are (4?).
Will this cause issues with the auto tranny? Whats the average cost to have the done?
Thanks
Sunday, September 1st, 2019 AT 12:08 PM (Merged)
CARADIODOC
  • 33,916 POSTS
Hi dick61045. Welcome to the forum. Don't forget, you're going to have to change the gears in the front axle too. I have a much better idea since this isn't a common problem. Look for a diesel shop that specializes in fuel injection systems. We have one in my town that does a modification to the injector pump that increases fuel mileage and boosts horsepower and torque a lot. They are also approved by Chrysler for performing warranty repairs.
You can also install the boxes they call "chips" that modify pump timing and increase power. My friend has two dually diesels with these boxes and either one will just about tear the tires off the wheels.
Caradiodoc
FABIAN83
  • 15 POSTS
  • 1999 DODGE RAM
  • 79,000 MILES
I have got a 1999 Dodge Ram 4x4 Sport and I recently installed a 5 inch suspension lift and 35 inch tires, I have been reading a few of forums that say with this setup it puts a lot of stress on the drive train and before I does harm to the transmission I am thinking of swapping out the factory 3:55 gears and replacing them with 4:56 which is what everybody say's you need to run this setup. What will I have to purchase to do this swap?
CARADIODOC
  • 33,916 POSTS
You're going to have to change the gear ratio in the front differential to match the rear one unless you want the front and rear wheels to turn at different speeds in four-wheel-drive. Engine noise will go way up. Luckily your truck has a solid front axle. With independent suspension, or worse yet, Ford's twin I-beam front end, there is no way to eliminate tire wear with any alignment settings. If your lift kit included a dropped pitman arm to keep the same geometry for the steering linkage, handling should remain somewhat normal.
FABIAN83
  • 15 POSTS
Yes it came with a pitman arm and the steering is good, what I wants to know is can I install the 4:56 gears by just purchasing the ring & pinion.
CARADIODOC
  • 33,916 POSTS
Yup, but you have to do both axles and they need to be set up by a specialist to adjust the proper preload and backlash. I did two axles with the service manuals handy. I don't ever want to do another one.
I'm still confused on what you were told about stress. The stress comes from the rubber control arm bushings being in a permanent twist from the suspension being lowered to raise the truck. The gear ratio has noting to do with that. 4.56s will give you quicker acceleration and usually lower fuel mileage but it won't change anything else. I can see where someone might think there would be less pressure on the universal joints but they can take that. The wear is also a factor of how far the needle bearings roll back and forth in the cups each drive shaft revolution. At the design height the cups are meant to turn back and forth a little so the needle bearings never stay in one spot and create dents in the rolling surfaces. Raising the truck increases the drive shaft angle which does not eliminate that rolling back and forth but it makes them roll further which I suppose could make them wear faster.
I think I'd talk with a few more people before you go to such an extreme measure of changing gear ratio without knowing what they're trying to solve. The impression I get is someone is trying to sell you an unneeded service.
FABIAN83
  • 15 POSTS
All the Dodge forums that I have been reading say's that running 35 inch tires with 3:55 gear ratio will make the transmission work extremely hard with all the down shifting trying to turn the big tires so they are saying using the 4:56 gear ratio will help take strain off the transmission. Will I need to purchase new bearings when changing the 3:55 for 4:56 gears?
IRONMAN.45.45
  • 2000 DODGE RAM
  • V8
  • MANUAL
  • 179,000 MILES
How to cange it
DR LOOT
  • 2,311 POSTS
Too much to explain you will have to purchase a manual from your local store, beginning operation and if you have any questions let me know and I will answer them for you
CARADIODOC
  • 33,916 POSTS
The bearings should be the same. Sounds like the idea is for the faster-turning drive shaft to offset the need for the wheels to turn slower since the outer circumference will be bigger. You may run into an issue with the speedometer. As I recall, the speed sensor is still run by a plastic gear in the tail housing of the transmission. The service manual should have a chart that crosses the tire size and axle ratio to determine the correct number of teeth on that gear. Some car models have a pulse generator, then the tire size and axle ratio have to programmed in with a scanner. Those have a very limited number of choices and if you modify something enough and the needed choice isn't listed, you're out of luck.
In your case, a higher gear ratio and larger tire circumference might offset each other enough that the speedometer will be close. Look for one of those roadside speed indicators to check your speedometer. I've found them to be pretty accurate.
FCOX062511
  • 1995 DODGE RAM
Im having some trouble with the rear end in my 95 ram 2500. From what I could gather, the rear end I should have is a dana 70 with 3.55 ratio. I ordered a rear end for this truck and it was slightly bigger and the brakes were different. When I switched it all over and put the rear end in, the four wheel drive no longer works, the speedometer is off and the front tires lock up. This means they sent me the incorrect rear end right? Im thinking the one they sent me was a dana 80 with 4.10 ratio. Is the dana 80 rear end bigger than the dana 70?
CARADIODOC
  • 33,916 POSTS
You can go to a larger axle physically but you do have to stay with the gear ratio that matches the front so the two drive shafts turn at the same speed. Look for a small metal tag under one of the differential cover bolts. The gear ratio will be stamped on it.
There is also a consideration with the brake size because that was carefully designed in with the size of the front brakes to create a balanced braking system front-to-rear. Look at the shoe width, lining length, and drum diameter first. If those are different the braking forces will be different. If they're the same you also must consider the diameter of the wheel cylinders. That affects how much force is put on the shoes. If you have rear-wheel anti-lock brakes, that will reduce easy rear-wheel lockup, but still, that is the type of thing insurance investigators and lawyers look for when they're trying to shift some of the blame for the crash from the other guy who ran the red light onto you.
