No power to injectors 88 Dodge Ram
1988 DODGE RAM
NJULLMAN
1988 Dodge Power Ram 100 5.2L TBI AUto 4x4 134,000 miles.
Truck will intermittently die off. There is little to no voltage at the fuel injectors while cranking. Will idle fine at times but when put into drive the engine loses all power, it will still run but will not accelerate. It will however accelerate in nuetral or park. I recently installed a new pump in the tank and two new injectors as I had figured that would fix the problem but it still occurs. Im thinking maybe a bad computer or ASD?
Jun 4, 2007 at 2:37 PM
E40WATER12
  • 522 POSTS
How old is the fuel filter?. I would check the pressure on the fuel pump again. How long has it been since youre truck has had a full tune up?. Also you have a problem with you Distr, module.
Jun 4, 2007 at 8:36 PM
NJULLMAN
Fuel filter is brand new pressure is also good it recieves solid fuel delivery just no power to the injectors to open up. I am getting spark as well.
Jun 5, 2007 at 3:04 PM
