1994 Dodge Ram 1500 Front Rotor Change Fix
CMACK69ER
how difficult is it to change th efront rotors on a 1994 dodge ram 1500 4x4? is it as easy as the rotors on my camaro?
Apr 18, 2007 at 10:19 AM
LSUSSEL
  • 252 POSTS
you need to remove the caliper and brake pads, if you change the rotors, you must as well change the pads, sometimes the pad form to the rotor and if the rotor is warped and what not...it would be forming to the old rotor which wouldnt be the same width and the new rotor and could cause problems
Apr 20, 2007 at 4:13 PM
Suggested Repair
Remove the caliper and brake pads to replace the front rotors, and install new pads at the same time so they are not formed to the old rotor.
Conversation Summary
The owner asks how difficult it is to change the front rotors on a 1994 Dodge Ram 1500 4x4 compared with a Camaro. The expert says to remove the caliper and pads, and to replace the pads with the rotors because used pads can be formed to a warped or different-width rotor and cause problems.
