2001 Dodge Ram Front brake rotor removal
2001 DODGE RAM
125,000 MILES • 6 CYL • 4WD • AUTOMATIC
BARTSDAD
I have a brand new set of front rotors for my 2001 Dodge 2500 Ram, but have run into a road block. There is a large Trox headed bolt that holds the caliper bracket in place. I do not have that size of external Torx socket, and with the price of a complete set, I might as well have the dealer change the rotors for me. Do you know what size of Trox socket is required for the removal of this Torx fastener? Thanks!
Jan 9, 2008 at 5:03 AM
ALBOUDREAU
[quote:dd80e5ab60="BartsDad"]Brakes problem
2001 Dodge Ram 6 cyl Four Wheel Drive Automatic 125000 miles
I have a brand new set of front rotors for my 2001 Dodge 2500 Ram, but have run into a road block. There is a large Trox headed bolt that holds the caliper bracket in place. I do not have that size of external Torx socket, and with the price of a complete set, I might as well have the dealer change the rotors for me. Do you know what size of Trox socket is required for the removal of this Torx fastener? Thanks![/quote:dd80e5ab60]
The size you need is an E-24 Torx socket!
Mar 30, 2021 at 2:34 AM
