dodge ram b350 van
GGSEAGLE
i have a 1994 dodge ram van b350, 5.9L/360cu. 4 speed automatic transmission a518, over 100,000 mi. it has a lock up torque converter. my problem is: it will not go in reverse, all the forward gear seem to work but when i put it in reverse it acts like at is trying to put forward but just cant. i removed the shift linkage and put it in gear with the shift rod on the transmission and got the same results. i can go in to the transmission if i have to but i dont want to un less i wave to. any ideas? thanks in advanced.
Sep 18, 2007 at 2:45 AM
WRENCH
  • 57 POSTS
There is one thing you can do or check and that is take off the trans pan and there is a reverse band adjusting screw you will need to back of the lock nut and then tighten the adjuster no more than 70 inch lbs. ( thats not very tight ) after you done this than you need to back off 2 full turns and then making sure the screw doesn't turn tighten the lock nut. ( not too tight you don't want to break it). Since your there and fuild drained change filter and pan gaskit. Remember that is INCH LBS. After that there is a adjuster on the out side for foward and its same thing tighten to 72 INCH LBS. but you want to back off 2 and 1/2 full turns. Then tighten lock nut. See if that helps.
Sep 18, 2007 at 5:04 AM
