1976 Dodge Ram Hot Load Knock
CTRICE
  • 5 POSTS
My 1976 Dodge pickup (95K miles, 318 engine) has severe valve rattle under load or going up hills and interstate on-ramps. This only occurs after it reaches full normal operating temperature. When it is cold and warming up this does not occur and runs fine. I have tried higher octane fuel and different plugs with no change. Anything but light acceleration causes the valves to sound is if they are coming through the hood. any help is appreciated.
Apr 5, 2007 at 9:02 AM
  • 75,988 POSTS
Sounds like spark knock/detonation/pinging
Check the ignition timing and EGR
Apr 5, 2007 at 5:04 PM
CTRICE
  • 5 POSTS
The timing is correct and I agree that it is probably spark knock just dont know why it is occuring. It is much worse in warm/hot weather also.
Apr 5, 2007 at 11:38 PM
  • 75,988 POSTS
[quote:7e614e2a31="ctrice"]The timing is correct and I agree that it is probably spark knock just dont know why it is occuring. It is much worse in warm/hot weather also.[/quote:7e614e2a31]
You sure its not overheating-did you check the EGR it will cause detonation if its not opening-Knock sensor not retarding the timing
If the insulator is split or chipped, detonation (spark knock) may be occurring in the engine. The underlying cause here might be an inoperative EGR valve, overadvanced ignition timing, excessive compression due to accumulated deposits in the combustion chamber, or engine overheating.
Apr 6, 2007 at 12:20 AM
CTRICE
  • 5 POSTS
I will check the EGR though I am not positive there is even one on this truck. It is 1976 and does not have a catalytic converter though it does have a charcoal canister. I heard pickups did not need emissions equipment until around 1979. I inherited it from my Grandfather who purchased it new. thank you for the advice.
Apr 6, 2007 at 12:28 AM
  • 75,988 POSTS
[quote:61ccb123aa="ctrice"]I will check the EGR though I am not positive there is even one on this truck. It is 1976 and does not have a catalytic converter though it does have a charcoal canister. I heard pickups did not need emissions equipment until around 1979. I inherited it from my Grandfather who purchased it new. thank you for the advice.[/quote:61ccb123aa]
Do a wet and dry compression test and comeback with the results-if its higher than normal you got accumulated deposits in the combustion chamber-raising the compression to a point creating detonation
Pre-ignition and detonation is two different things
Apr 6, 2007 at 12:44 AM
CTRICE
  • 5 POSTS
Will do. Thank you and I'll let you know what I find out.
Apr 6, 2007 at 1:33 AM
Suggested Repair
Confirm ignition timing and that the engine is not overheating. Check whether an EGR valve is present and opening, and whether a knock sensor is failing to retard timing. Perform wet and dry compression tests; higher-than-normal compression points to combustion-chamber deposits causing detonation.
Conversation Summary
A 1976 Dodge pickup with a 318 engine develops severe rattle under load only after reaching full operating temperature, and it is worse in hot weather. Higher-octane fuel and different plugs did not help, and the owner says timing is correct. The expert identifies spark knock or detonation and recommends checking timing, EGR operation, overheating, knock-sensor timing retard, and wet and dry compression for deposit-related high compression. The owner plans to check and report results.
