Dodge 1500 Air conditioner clutch cycles on/off every 5 secs
DODGE RAM
BRENTA66
I have a 2001 Dodge Ram 1500 Quad cab 4X4 5.2l engne with auto trans. Air conditioner worked fine two weeks ago. Now the clutch just cycles on/off about every five seconds. Swapped know good relay and problem still there. Coolant level checked good. Console switch checked good. No leaks at all.
May 28, 2007 at 3:31 PM
PARISHERJ
  • 11 POSTS
Is the a/c still blowing cool? There are a few things that make one do that. If the evaporator gets to cold it will kick out the a/c clutch to prevent it from freezing. Most cars do this under normal operation. If it is low in freon it will kick out due to the low pressure switch. If the system is getting to hot,( fans not working or clogged condensor) the high pressure switch will kick it out.
May 29, 2007 at 10:59 AM
