a/c
T_MORLAND
2002 dodge 2WD 60,00miles 4.7L V8. recently while running the air cond. it sounded like something behind a vent on the passenger side blew up and it blew debris out of the vent. since then when i run the a/c it makes a very loud rattling noise behind that particular vent. is it the fan motor?
Jul 16, 2007 at 2:58 PM
DPWD23
  • 136 POSTS
If the fan is easy to get to, you can pull it out and check. Not likely for the motor to cause it, but the actual fan blades (it looks like a mouse wheel).
If nothing else, you probably got some debris in there that needs to come out. Removing the fan SHOULD give you access to some of that area to vacuum it out. If it's in the duct work, some exploitory surgery will be needed to find the actual cause of the noise.
Jul 19, 2007 at 4:32 PM
