99 Voyager Radiator fan relay
HSIMPSON
99 Dodge Voyager
Does anyone know where the fan relay is? The wiring diagram says it is on the left frame rail but I can not see it.
thank you.
Harry
Jul 26, 2006 at 10:39 AM
HSIMPSON
First, I made a mistake. It is a Plymouth Voyager but the Dodge Caravan is the same.
I see there are many people with this same problem so here is the answer.
Chrysler put a solid state relay just off the wiring harness near the radiator. Take a 10mm wrench and remove the air intake ductware. Look where the wiring harness turns to go across the radiator. You will see a flat solid state relay with a connector like a connector for a TPS switch.
I was told this is a common problem. It is an easy problem to fix if you know where the relay is.
I hope this helps.
Harry
Aug 3, 2006 at 12:45 PM
SUDSY
it is rt behinde the air filter secure with 2 sheet matel 8 mm screws
Aug 6, 2006 at 3:51 AM
