Dodge going dead when i take foot off gas, in forward or reverse already changed idle air motor ,throttle position sensor ,map sensor.
Feb 6, 2007 at 2:32 AM
BUBBA_KOSKI
✓Experienced Mechanic
i had the same problem, drain flush fill and change the transmission filter (if auto) add 2 ounces of lube guard to it. What happens on most dodge pu is that the engine stalls out when fluid id well for lack of a better term not good, well when your tanny is burning up, the motor stalls out.
