2008 Dodge Ram wheel studs
55,000 MILES • V8 • 2WD • AUTOMATIC
TJPRINTING
How do I replace rear wheel studs?
Oct 25, 2010 at 7:29 AM
MENDOZA__
  • 20 POSTS
In Order to replace the wheel studs you will have to tap them out. First you will want to remove the tire and hub. Then once that is removed, you will have to remove the plate holding the studs, lay it on a flat surface with one cut area to tap out the stud. Use a big flat faced hammer to tap it out. If your still not to sure go to youtube.com and enter removing wheel studs to get a visual image, much more detailed. Hope this helps out.
Oct 28, 2010 at 8:56 AM
