2007 Dodge Ram Synthetic Oil Questions
29,000 MILES • V8 • 4WD • AUTOMATIC
BWHEELERSC
I just bought a 2007 Dodge Ram 4x4 with the 5.7L Hemi. I am thinking about using synthetic oil. I do not know a lot about synthetic. The manual says that its fine to run it. I am willing to pay the extra money for better oil for peace of mind, knowing my engine is going to last longer. What are the disadvantages of synthetic other than price?? Thanks
Mar 19, 2009 at 7:49 AM
BLACKOP555
  • 10,386 POSTS
diesel engine?
synthetic is supperior to regular oil besides price. thats it!
runs better at all times.
just more expensive. dont go with off brand synthetics
Mar 19, 2009 at 2:00 PM
BWHEELERSC
No it is not a diesel. 5.7L Hemi Gas. Also the Mopar asks for 5w-20. Will that change if i want to go to synthetic? Also I live in Kansas, where it can push 110 degrees, should i be using 5w-30 for the higher temperatures to be sure i am protected in the heat?
Thanks
Mar 19, 2009 at 11:39 PM
BLACKOP555
  • 10,386 POSTS
10w30 if you get the heat up in the 110's escpecially with the heat that hight.
synthetic is the same thickness as regular oil.
Mar 20, 2009 at 12:20 PM
MEGADODGE.5.7
[quote:eeb1b5407a="bwheelersc"]No it is not a diesel. 5.7L Hemi Gas. Also the Mopar asks for 5w-20. Will that change if i want to go to synthetic? Also I live in Kansas, where it can push 110 degrees, should i be using 5w-30 for the higher temperatures to be sure i am protected in the heat?
Thanks[/quote:eeb1b5407a]
No, do not change the weight when you move to synthetic. My 03 5.7 hemi required 5w-30 and it developed the hemi tick by 5,000 miles. Dodge figured this out and now my 06 requires 5w 20, 52,000 no tick. Any thing heavier makes them tick. Engines these day are built to tight tolerences and having to heavy oil will cause them to hydraaulic lock and thats why you here the tick. The synthetic I use is mobile 1. Make sure you stick to the recommended service intervals even if you use syntrhetic, its just good insurance.
Mar 24, 2009 at 4:58 AM
BLACKOP555
  • 10,386 POSTS
good advice megadodge. thank you for picking this post up on my absence!
Mar 24, 2009 at 1:19 PM
