2007 Dodge Ram idles at 2000 rpms all the time
64,000 MILES • V8 • 2WD • AUTOMATIC
BEVERLYHILL
my 2007 Dodge truck idles at 2000 rpms all the time. Why is this?
Mar 11, 2010 at 11:16 AM
OBXAUTOMEDIC
  • 3,712 POSTS
There are a few possibilities....
First off is the engine light on? If so go by your local parts store and ask them to pull codes. Write them down and post them here in forum.
Here are a couple possibilities....
IAC - Idle Air Control Valve
TPS - Throttle Possition Sensor
Vacuum Leak
Any of which should turn the engine light on.
Mar 11, 2010 at 11:32 AM
BEVERLYHILL
No the check engine light is not on
Mar 11, 2010 at 12:52 PM
OBXAUTOMEDIC
  • 3,712 POSTS
Ok, does the engine light come on for few seconds when key is turned to possition? If not the bulb may be burnt out. And having codes pulled would help.
If does come on then would need to start looking for a vacuum leak. They can be a pain to find, it took me on a mini-van almost 4 hours to locate the small little hose, about an inch long, that was the cause.
Common leak paths include the throttle body gaskets, intake manifold gaskets, and of course, any of the engine's vacuum fittings, hoses and accessories. It is even possible that leaky O-rings around the fuel injectors are allowing air to leak past the seals. Another overlooked item can be a worn throttle shaft.
Mar 12, 2010 at 12:36 AM
BEVERLYHILL
The engine light comes on when starting the vehicle like it is supposed to. It is being taken this morning to get checked out by a mechanic. Thanks for all your suggestions.
Mar 12, 2010 at 1:52 AM
