2007 Dodge Ram A/C
3,500 MILES • 6 CYL • 2WD • AUTOMATIC
ADOG77D
A/C clutch want engage. What do I need to do?
Sep 18, 2009 at 3:47 PM
DR LOOT
  • 2,311 POSTS
Most likely the problem is, there is not enough pressure in the system to activate A/C pump, you will have to follow your hoses until you come across a low pressure switch. It will only have two wires, take a jumper wire and jump it. that will activate the clutch. So you could put some free on in it.
Sep 21, 2009 at 5:48 AM
