2006 Dodge Ram water temp
2006 DODGE RAM
NPALACIOS7
Engine Cooling problem
2006 Dodge Ram V8 Two Wheel Drive Automatic
my 2006 ram 1500 quadcab seems to have some difficulties. for example when i drive the water temp needle moves a little past the center line then goes back and it will keep playing itself like that until i shut off the truck. then the oil temp does so also. and the battery needle sometimes moves too. what do i need to do?
Feb 10, 2010 at 5:46 AM
TOOOMANYTOYS
  • 513 POSTS
Some slight movement is a normal operation. Coolant temperature, oil pressure, and battery voltage constatantly change values. If the gauge move alot abnormally i would have the gauge cluster checked. Might just be a loose connection going into the cluster.
Feb 10, 2010 at 5:54 AM
