when i'm sitting at the lights my rpms drop to 200 or sometimes 0 and other times it seam to work ok
Aug 11, 2010 at 8:18 AM
✓Experienced Mechanic
Is the engine dieing, or is the problem only with the tach?
Aug 11, 2010 at 2:12 PM
RAMHUNTER
MEMBER
just the tact
Aug 11, 2010 at 3:33 PM
It could be a few things, a bad signal from the PCM, BCM, or a bad ground. Have you checked for bad or loose body grounds?
Aug 11, 2010 at 4:04 PM
RAMHUNTER
MEMBER
on the 2006 dodge ram the tact is closed all in and what ground wires are you talking about. i will also check the pcm and the bcm
Aug 12, 2010 at 4:19 AM
There are body grounds that look like straps. They are usually held on with clips. Often, they rust or come loose.
Aug 12, 2010 at 4:24 PM
