2006 Dodge Ram Stop Leak
46,742 MILES • 6 CYL • 4WD • AUTOMATIC
WOODCHUCK81
Local dealership advises my evaporator has a leak within & needs to be replaced. I currently don't have $1100.00 for the repair but NEED A/C.
My ?
Will a/c stop leak, (such as RED ANGEL or SUPER STOP LEAK PLUS) damage my system if professionally installed per spec's?
Thank you for your honest opinion.
Jul 15, 2010 at 11:57 PM
  • 110,251 POSTS
It really depends on how bad the leak is if it will work. As far as the product, I have no recommendations as far as manufacturer, but as long as you follow their directions, everything should be okay.
Jul 16, 2010 at 3:08 PM
WOODCHUCK81
Thank you for your speedy reply.
I realize that stop leak additives can only stop minor leaks within the system.
My concern is that most of these stop leak compounds are air activated.
Once injected into the system they, as the rest of the freon, seap out at the hole & once air hits the stop leak compounds begins to harden and form a weld/patch.
With that said, If the stop leak is injected into the system and the hole is too large to seal or another hole appears in the system with the stop leak in it, will air get into my system causing the stop leak to active, wherefore becoming a solid within the system and destroying the entire system?
Jul 16, 2010 at 9:55 PM
  • 110,251 POSTS
That shouldn't happen. If the leak is too big, it just won't work. I have never seen it cause the entire system to plug, but the is a legitimate concern.
Jul 17, 2010 at 7:07 AM
