2006 Dodge Ram serpentine belt replacement
90,000 MILES • V8 • 2WD • AUTOMATIC
HATCH81
How do i replace the serpentine belt for a 2006 dodge ram 1500 4.7. I dont know how to loosen the belt tension pulley . And if the pulley is bad how do i replace that
Feb 8, 2010 at 3:14 AM
TOOOMANYTOYS
  • 513 POSTS
This vehicle has a self tensioner on it. Using a large 15mm wrech on the tensioner pulley relieves the tension so the belt can be removed. Make sure the tensioner is not frozen or binding. Also make note of how belt is routed before removing it.
Feb 8, 2010 at 3:24 AM
