2006 Dodge Ram brake repair
87,000 MILES • V8 • 2WD • AUTOMATIC
RONIHASTINGS
I just changed my front rotors, pads and calipers. I bleed the system from the calipers and the pressure on the pedal builds up but then when I turn on the truck the pressure is gone and I cant get it back. I pedal just goes to the floor. Only after starting the truck. I have checked for leaks and see none around the lines going to the new calipers.
Mar 24, 2009 at 5:21 PM
DOCFIXIT
  • 18,828 POSTS
Have you tried bleeding with engine running? May have gotten air in ABS modual
Mar 25, 2009 at 4:05 AM
