2006 Dodge Ram Brake problems
58,000 MILES • V8 • 2WD • AUTOMATIC
SHARPIE8927
I have a 2006 Dodge Ram 5.7 Liter 1500 SLT, with all disk brakes. SOMETIMES when appling the brakes the brakes will hammer or pound, it does not feel like the ABS pulsating. The brake light, ABS and engine light does NOT come on. I tried changing the brake pads, and also tried disabling the ABS system by unplugging, but the problem is still there. Could it be a bad master cylinder or bad caliper? It feels as if the problem is coming from the front . I would appreciate any imput.
Thanks,
Sharpie8927
Sep 7, 2009 at 4:30 AM
JSWAIN
  • 24 POSTS
Have you checked to see that rotors are not warped? Also would check all caliper mounting bolts to see that they are not loose. Hope this helps.
Sep 10, 2009 at 3:09 PM
