I am getting a vibration when pulling out from a stop. It seems to be worse when I pull out into a turn. I subsides after I get moving.
May 19, 2009 at 12:53 PM
✓Experienced Mechanic
Check for bad u-joints and axle joints. Also, make sure motor and trans mounts are in good condition and not loose or broken causing a bind on the drive line. Let me know what you find.
