transmission seems to slip like there is no power?
PANTERANEGRA
  • 12 POSTS
Can you get me some pointers on these codes? I have read what it says about them but I am not sure what to check. I would like to try to fix it if I can because I do not know of a mechanic I can trust. The transmission seems to slip like there is no power and it takes a little bit to gain speed. Later it works okay.. Thank you for your help.
Jul 30, 2009 at 6:21 AM
BMRFIXIT
  • 19,053 POSTS
p0700-transmission control system (mil request)
diagnostic test
1) dtc present in eatx controller
this is an informational dtc letting you know that a dtc(s) is stored in the transmission control module.
erase this dtc from the pcm after all transmission dtc(s) have been repaired.
using a scan tool, read the transmission controller dtc and refer to the transmission category and perform the appropriate symptom.
p0876-ud pressure switch rationality
possible causes
related relay dtc's present
low fluid level
no. 2 check ball cut or damaged
low line pressure
cracked or misinstalled sump filter or seal
sticking main regulator valve in pump valve body
(t29) ud pressure switch sense circuit open
(t29) ud pressure switch circuit short to ground
(t29) ud pressure switch sense circuit short to another circuits
transmission solenoid/trs assembly
powertrain control module
theory of operation
the transmission system uses five pressure switches to monitor the fluid pressure in the lr, 2c, 4c, ud, and od clutch circuits. the pressure switches are continuously monitored for the correct states in each gear as shown.
Jul 30, 2009 at 2:03 PM
PANTERANEGRA
  • 12 POSTS
I have read what you posted in the service manual. I check the fluid level and is okay. can you tell if there is a relay I need to check (Related relay DTC's present). Sump filter is this referring to the transmission filter? o is there another filter. Sticking main regulator valve in pump valve body is this located inside the transmission? Transmission solenoid/transmission assembly power-train control module.
Can you tell me where are these located? Thank you for your prompt response.
Jul 31, 2009 at 2:32 AM
BMRFIXIT
  • 19,053 POSTS
technical service bulletin reference number(s): 21-007-06, date of issue: april 07, 2006 chrysler:2005 - 2006 (dr) ram truck; 2005 - 2006 (hb) durango; 2005 - 2006 (kj) liberty / cherokee; 2005 - 2006 (nd) dakota; 2005 - 2006 (wk / wh) grand cherokee; 2006 (xk) commander group:transmission rfe transmission filters - delayed engagement and related transmission dtc's overview: this bulletin involves verifying the build date of the transmission, and if necessary, the replacement of both the cooler return and sump filters in the transmission. note:this bulletin applies to vehicles equipped with the a 45rfe or a 545rfe automatic transmission (sales code dg4 or dgq respectively) having a specific transmission build date code (see the below diagnosis section for further details). symptom/condition: the customer may experience an initial delayed shift engagement following an extended off (not running) period of time, generally after being parked overnight. the initial shift engagement may feel like a delay or slip when a transmission gear (reverse or drive) is first selected after engine start. the customer may also experience a mil illumination. investigation may determine that the mil is due to one or more of the following diagnostic trouble codes (dtc's): p0868 - line pressure low. this dtc will be the most frequently occurring dtc for the delayed shift condition. p0944 - loss of hydraulic pump prime. p0731 - gear ratio error in 1st. p0736 - gear ratio error in reverse. p0841 - lr pressure switch rationality. p0876 - ud pressure switch rationality. the delayed engagement and mil condition (dtc's) may be caused by a suspect transmission cooler return filter with a part number of 04799662ab . a suspect 04799662ab cooler return filter may cause the transmission sump filter to split at its plastic-to-metal crimp. if the transmission sump filter becomes split at the crimp, then one or more of the above dtc's may also occur. diagnosis: turn the ignition to the "off" position. raise the vehicle on a suitable lift. fig. 1: trans identification number inspect for the transmission build date (julian date) (fig. 1). the transmission build date can be determined by inspection of the 20 digit transmission identification number (dddyxxxxxp partnumber). the transmission identification number is stamped on the left side (driver side) of the transmission oil pan flange. the first four (4) digits of the transmission identification number are the transmission build date, in julian date format. an example of a transmission identification number would be : 1015 10492p52119684aa. the first three digits (101 ) of the identification number equal the day of the year, in this case 101 equals april 11. the fourth digit ( 5 ) of the identification number equals the calendar year, in this case 5 equals 2005. so 1015 equals april 11,2005. determine if the vehicle's transmission was built on or between one of the two sets of julian date build ranges listed below: julian date 0425 (february 11, 2005) to julian date 0455 (february 15, 2005). 0425 to 0455. julian date 1015 (april 11, 2005) to julian date 2345 (august 22, 2005). 1015 to 2345. if the vehicle has the above condition, and if the transmission julian build date is on or between the range of dates listed above, perform the repair procedure. note:both the transmission cooler return filter and the transmission sump filter must be replaced at the same time. parts required: note:do not use a replacement cooler return filter with a part number of 04799662ab. this filter is suspect of causing the above condition. the cooler return filter part number is stenciled on the side of the filter's metal case. parts description qty.part no.description 104799662filter, transmission cooler return (ar) 105015267ackit, transmission sump filter - 4x2 (verify p/n for specific vehicle) (ar) 105013470ackit, transmission sump filter - 4x4 (verify p/n for specific vehicle) 405013457aafluid, automatic transmission, ms-9602 atf+4, quart 105010884aamopar atf-rtv special tools/equipment required: special tools 8321oil filter wrench repair procedure: note:all cooler return filters with the "ab" suffix (04799662ab) are suspect. the above condition may be corrected by replacing a suspect "ab" filter with a new cooler return filter whose part number is 04799662 (with no suffix or with a suffix that is other than the "ab" level), and a new sump filter. note:both the sump oil filter and the cooler return filter must be replaced in the transmission at the same time. do not replace one filter without also replacing the other filter. note:a replacement 04799662 cooler return filter may come packaged with a separate threaded adapter stud. the threaded adapter stud is used to attach the cooler return filter to the transmission. inspect the stud and note end without threads. install the stud end without the threads into the cooler return filter and tighten the stud-to-filter connection to 18.6 nm (165 in. lbs.). once the threaded adapter stud has been installed to the cooler return filter, install the assembled cooler return filter to the transmission and tighten the filter to 14.1 nm (125 in. lbs.) fig. 2: transmission filters - 4x4 shown use the procedures outlined in techconnect(r) ( service information tab / 21 -transmission transaxle / automatic - 45rfe 545rfe / fluid / standard procedure / fluid and filter replacement) to replace both the transmission cooler return filter and the transmission sump oil filter. note:always install the sump filter seal to the bottom of the transmission oil pump first, then install the sump filter to the oil pump and previously installed seal. do not install the sump filter seal to the sump filter and then attempt to install both to the oil pump.
https://images.2carpros.com/forum/automotive_pictures/99387_graphic1_437.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_graphic2_217.jpg
let us know if this fixes it.
Aug 1, 2009 at 3:44 PM
