i have a dodge ram 2500 5.7l everytime i get to a stop the engine stalls.
Feb 14, 2010 at 7:02 AM
✓Experienced Mechanic
Has the check engine light come on? Have you checked for vacuum leaks? Have you checked fuel pump pressure?
Feb 19, 2010 at 3:24 AM
TEXAS214
MEMBER
yes the check engine light has come on...no i haven't checked for anything else but we did change the throttle body..i think its the idle air control vavle but not sure
Feb 19, 2010 at 10:37 AM
I would think the IAC would set an engine code. However, it is possible that it won't.
Feb 20, 2010 at 12:24 PM
TEXAS214
MEMBER
i have scan the truck for any codes but the scanner doesn't find a problem....if it had a vacuum where would it most likely be located
