2005 Dodge Ram No 4 wheel drive
94,000 MILES • V8 • 4WD • AUTOMATIC
LBK0ZZ8
The 2 wheel drive in my Ram works fine & shifts fine between gears......When I use the floor shift to put it into 4 wheel drive, nothing happens.....No light on dash to tell me it's in 4 wheel drive....No noises what so ever....Any simple solutions that my mechanic can check or do I need to take it to a Transmission Shop ????
Aug 17, 2010 at 5:36 AM
  • 110,244 POSTS
first, make sure the linkage is attached and working. Next, there is a vacuum switch on the front of the transfercase with 4 vacuum hoses going to it. Check if any of them are damaged or disconnected. Also, check for vacuum to the front axle.
Let me know what you find.
Aug 17, 2010 at 5:02 PM
