Temperature runs high. I replaced clutch fan a year ago. I had radiator flushed, fins cleaned and replaced themostat.
May 9, 2010 at 6:57 AM
✓Experienced Mechanic
How hot is it running? Has it ever boiled over? If not, are you sure the gauge is reading correctly? Check and test the coolant temperature sensor, thermostat and water pump.
