Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Ram
Warning Lights
Check Engine Light
2005 Dodge Ram Fault code 0240
2005 DODGE RAM
65,000 MILES • V8 • 2WD • AUTOMATIC
CHRIS88
MEMBER
My check engine light came on this morning. The fault code was 0240, what is the problem?
Apr 15, 2008 at 1:37 AM
BMRFIXIT
Experienced Mechanic
Check code s again make sure u have the correct code
I do not believe p0240 will apply on yours
Apr 15, 2008 at 1:48 PM
CHRIS88
MEMBER
I wrote it down wrong, its p 0420.
Apr 16, 2008 at 1:42 AM
BMRFIXIT
P0420 catalyst efficiency
1st check if you have an exhaust leak and if so fix it
check oxygen sensors and wiring
check catalytic converter
Apr 16, 2008 at 6:13 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
