2005 Dodge Ram fan belt pully
85,000 MILES • V8 • 4WD • AUTOMATIC
ERIKDICKINSON23
my fan belt pully is loose. I can shake it back and forth. Theres not a bolt that i can see to tighten it to the block. how do i tighten it
Feb 20, 2010 at 4:22 AM
DOCFIXIT
  • 18,828 POSTS
If 5.7L which one in diagram?
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_9.png
Feb 20, 2010 at 4:47 AM
COLT
  • 5 POSTS
probably need a new water pump, if that pulley is loose then im guessing the bearing went out on it and if its the fan belt that should be running the water pump also
Mar 4, 2010 at 2:07 PM
