Engine won't run I changed the spark plugs and filled the tank with new gas?
20,000 MILES • 6 CYL • 2WD • AUTOMATIC
KMDNE5
Accidentally put gas/oil mixture (about 2 gals) intended for chain saw in gas tank. It went about 1 miles and stopped. I changed the spark plugs and filled the tank with new gas. It only runs when gas is poured directly in carb. and then dies when that gas runs out. I've been told that it wasn't enough oil/gas mix to cause a major problem, but the truck is not running. any ideas? Thanks for your help.
May 28, 2009 at 2:20 PM
  • 75,988 POSTS
Check the fuel pressure this will tell you something could be a clogged fuel filter, the intank fuel pick up sock and fuel pump and check for injection pulses.
May 28, 2009 at 4:53 PM
KMDNE5
I don't understand your answer. How do I check those things?
Jun 1, 2009 at 5:52 AM
  • 75,988 POSTS
You need a fuel pressure gauge to read the fuel pressure. Could also be the injector/s are clogged. Listen to the injector/s while cranking the engine over is it making a clicking sound?
Jun 1, 2009 at 10:26 AM
