2005 Dodge Ram engine gets hot and # 5 cly misfires
83,000 MILES • V8 • 4WD • AUTOMATIC
GATORM4
  • 11 POSTS
I have replaced thermostat and waterpump but truck is
still running hot. After driving several miles after parking
overnight goes into overflow tank but does not draw back
into radiator. I have to add coolant each time it is driven.
What else do I need to replace to correct this problem?
Engine light came on, had it checked at Auto Zone and
code showed #5 cylinder misfiring, there is no sign of water in oil. Any suggestions will be appreciated.
Sep 1, 2010 at 4:22 PM
  • 31,937 POSTS
Hi there,
Thank You for the donation,
have the pressure cap tested as if it is faulty you will not drew back into the radiator, also pressure check for any external leaks, check for a faulty plug & lead or coil if COP system, also any local vacuum leak around No 5 cyl.
mark (mhpautos)
Sep 1, 2010 at 6:10 PM
GATORM4
  • 11 POSTS
got a new cap still goes into overflow tank after driving
but still not going back into the radiator
will check the pug and wire and for vacuum leak
how do you check the coil to see if it is bad
Sep 3, 2010 at 2:14 AM
  • 31,937 POSTS
Hi there,
if the coolant will not draw back into the system with a new cap, there will be a small leaks somewhere as when the system is cooling it creates a partial vacuum which causes atmospheric pressure action on the head of coolant to flow back into the system, with no partial vacuum, pressures are equal and you get no flow, do you own and know how to read a multimeter for the coil tests?
Mark (mhpautos)
Sep 3, 2010 at 2:39 AM
GATORM4
  • 11 POSTS
yes i know how to read a mulimeter. in be a small leak
Sep 5, 2010 at 6:34 AM
  • 31,937 POSTS
https://www.2carpros.com/topics/electrical/coil-pack
Mark (mhpautos)
Sep 5, 2010 at 11:47 AM
GATORM4
  • 11 POSTS
do you check coil pack the same way.
Sep 5, 2010 at 5:26 PM
  • 31,937 POSTS
I will look for the specific test for the coil pack, sorry should of realized that.
mark
Sep 5, 2010 at 7:24 PM
GATORM4
  • 11 POSTS
engine is running rough took auto zone and had check
now 3 cly and 5 cly misfiring
Sep 6, 2010 at 12:13 PM
  • 31,937 POSTS
I will require a specific model & engine size as Dodge Ram is not info for detailed searching.
mark (mhpautos)
Sep 6, 2010 at 12:34 PM
GATORM4
  • 11 POSTS
I have run compression check on all cyls. All have 150lbs
except no. 3 is 120lbs. Ran computer chk shows 3 - 5 cyl
misfiring but have changed plugs on all eight and cleared
check eng light code and now no. 3 is still misfiring. Have
changed coils, moved no 3 to no.1 and 1 to 3 hoping it was a coil, clleared check eng code again, and no. 3 is
still misfiring. A brand new pluig is black, does this mean
cyl too rich.? At loss for what to do now. Any suggestions?
Sep 9, 2010 at 2:16 PM
  • 31,937 POSTS
Either you have a faulty injector or the low comp is causing you a problem, do a wet comp test to see if it is rings or a valve causing the lower compression.
Mark (mhpautos)
Sep 9, 2010 at 7:23 PM
