2004 Dodge Ram repair
AGUILARF
Engine Cooling problem
2004 Dodge Ram V8 Two Wheel Drive Automatic
4.7 engine overheat problem
Aug 23, 2009 at 3:34 PM
  • 31,937 POSTS
Hi there,
Check for coolant leaks with a cooling system pressure test, check the pressure cap, replace the thermostat and have the radiator cleaned & flow tested, if fitted with electric cooling fans make sure that they are turning on, start here.
mark (mhpautos)
Aug 23, 2009 at 6:07 PM
