2004 Dodge Ram OBD codes
66,000 MILES • V8 • 4WD • AUTOMATIC
BRIANBRUNSEN103
I have heard from some that I can pull the OBD codes by doing a key sequence and looking at the odometer. I have tried the on off on off on sequence from the older Dodges and it will not work. Is there a sequence for the 2004 model trucks? Thanks, Brian
Sep 23, 2008 at 11:18 AM
BMRFIXIT
  • 19,053 POSTS
What should work is key on off on off on
with in 10 sec
read P codes in the odometer area
Sep 23, 2008 at 11:25 AM
WOODYWOOD
what you need to do for p-code on 04 ram is simple. 1. hold the trip odometer down.
2. while still holding the trip odometer down turn key on.
the odometer will cycle through, and when finished the p- code will be present in the odometer section. that's it. good luck to all.
Dec 13, 2008 at 8:30 AM
