2004 Dodge Ram
2004 DODGE RAM
135,000 MILES • V8 • 2WD • AUTOMATIC
FERENC70
My truck has 135000k miles on it. A few days ago i noticed while sitting in rush hour traffic that the temperature would get way past the halfway mark, almost to the overheating mark. Once i got past the traffic the temp gage would show normal temp again up untill i caught a red light. Then the temp would rise again quickly. I checked the coolant level and it seems fine. I replaced the thermostat but that did not fix the problem either. Could the waterpump be causing the problem?
Feb 2, 2008 at 10:49 PM
MWOLOWS803
when a water pump goes bad it leaks fluid out and you would see it on the ground if the fins on the inside of the pump broke off the fluid wouldnt flow you have to take off the pump to see if they are ok another thing to look for is to see if your radiator is pluged run the truck till its hot and feel if the whole rad is hot if only half of it is hot and the other is cold or cooler then the other it maybe your problem that was mine problem
Mar 13, 2008 at 11:52 PM
MWOLOWS803
also check your anti freeze with a anti freeze tester it might be bad and not able to cool the engine even if the rad if full
Mar 13, 2008 at 11:55 PM
