2004 Dodge Ram Low idle and stall at idle
2004 DODGE RAM
110,000 MILES • V8 • 2WD • AUTOMATIC
ALLENC450
When I como to a stop in my truck, the idle drops down to below 500 and either cutts off or jumps back up and is good until I take off and stop again. I have cleaned the throttle body with carb cleaner and a tooth brush and it doesn't cut off as much but it still tries to. What should I look into next?
Mar 17, 2010 at 8:41 PM
BMRFIXIT
  • 19,053 POSTS
Also remove IAC valve and clean
if battery was disconnected before the clean was done have to disconnect battery
clean throttle and IAC valve reconnect battery and drive for few miles
for the PCM to relearn idle
check for ant vacuum leaks
check intake manifold gasket for leak
Mar 17, 2010 at 9:09 PM
