Something had to get into the cylender to crush the electrode on the plug, or you have a bad wrist pin or connecting rod bearing. Were the electrodes bent shut or broken? As far as oil into the air filter, there has to be a breather from the engine to the airfilter. Even if there is no PCV, there has to be a hose leading to the filter box from the engine. Otherwise, there couldn't be oil getting to it. At work tomorrow, I'll check if a ram with a hemi is there or if one comes in and look at it.
Just an after thought... Have you ever heard any rapping, knocking, ticking... from the engine?
Apr 23, 2010 at 1:24 PM
