2004 Dodge Ram how to change bearing
2004 DODGE RAM
100,000 MILES • V8 • 4WD • AUTOMATIC
DODGEMAN2004
i have a 2004 Dodge Ram 1500 4x4 , my left front wheel bearing has gone out and I need to replace it , the problem I have is i need to know how do I get the three bolts out that are behind the bearing that holds the hub on , i have tried to use a swivel socket but I still dont have enough room to get the bolts out there is a lip on thecv joint that is in the way...THAnks
Jul 10, 2009 at 7:21 PM
BMRFIXIT
  • 19,053 POSTS
Remove axle nut
and tie rod end use a socket and extension Back off the hub/bearing mounting bolts 1/4 inch each.
Then tap the bolts with a hammer to loosen the hub/bearing from the steering knuckle.
Jul 10, 2009 at 8:29 PM
