2004 Dodge Ram Horn blowing continuously
60,000 MILES • V8 • 2WD • AUTOMATIC
BHUDGENS47
The horn started to beep occassionally, then started blowing continuously. We pulled the fuse to stop the blowing. Now the battery has run down. The battery is new. Any idea what's wrong? Do you know what the estimated repair cost would be?
Oct 20, 2009 at 9:38 AM
SERVICE WRITER
  • 9,123 POSTS
Charge the battery and when it blows, disconnect the horn pad and see if it stops. If it does, replace the airbag. Horn switch is in the air bag. IF not, the clockspring is the most likely source.
https://images.2carpros.com/forum/automotive_pictures/30961_ramhorn_1.jpg
Oct 20, 2009 at 12:50 PM
