2004 Dodge Ram headlight
55,000 MILES • 6 CYL • 4WD • AUTOMATIC
RAM 3500
How do you remove 2004 Ram 3500 headlight for bulb replacement? Thanks Rebecca
Apr 25, 2010 at 11:19 AM
  • 110,248 POSTS
Are you able to access it from under the hood?
Apr 26, 2010 at 1:43 AM
RAM 3500
No, I can't get to it from under hood. I can't access the screw on bottom left side of light. It's way back between the bumper and bottom of light unit. Nothing will fit in there. Must be a special tool. Only low beam burnt out. It is the passenger side light. Dealer will probably charge an arm and a leg just to replace bulb. Thanks for your reply.
Apr 26, 2010 at 3:21 AM
  • 110,248 POSTS
Are you able to access the light sockets without removing the light assembly?
Apr 26, 2010 at 4:24 AM
RAM 3500
Thank you for your help. My nephew showed up and did it. It just required a long thin extension to go in between bumper and headlight to remove third screw. Now I know how to do it.
Apr 26, 2010 at 9:11 AM
  • 110,248 POSTS
I'm glad you got it fixed. Nothing ever seems easy anymore.
Apr 26, 2010 at 3:44 PM
