windows stopped going down where the fuse panels?
88,000 MILES • V8 • 2WD • AUTOMATIC
MLISTRE65
All four windows stopped going down at the same time. I need to find the fuse and test them.
Sep 29, 2008 at 7:16 AM
This could be the fuse on the side of the steering column but it could also be the Driver Door module. So check the fuse using this guide:
If that checks out then I would replace the module which is basically just the master window switch bank.
Please run though this material and let us know if you have other questions. Thanks
Jul 4, 2021 at 3:28 AM
